Castle Creations 9,000kv Brushless Motor
No you did not read this wrong and no it is not a typo. Castle Creations has created a 9,000Kv brushless motor for the Mamba Max with a 2S Lipo,to be used in 1/10th scale RC’s. What 1/10th scale RC I don’t know but if you find one to put this into, then it will fit.
Most people can’t even drive an RC that is loaded with a 7,700Kv brushless motor which spins at about 61,000RPM. Well Castle Creations new 9000Kv motor spins at about 72,000RPM, effectively ensuring that pretty much nobody will be able to handle!
Castle Creations 9000kv Specifications:
- Input Voltage: 6-8 NiCad/NiMh MAX / 2s LiPo MAX
- Size: 1.4″ dia. x 1.7″
- Weight (w/wires): 7.0 oz (198.4g)
- Shaft Size: Standard 1/8″ (3.2mm)
- Bearings: Oversize ABEC-1 front and rear
- Connector Type: 4mm gold connectors
Part #: CMS-9000 – Castle Creations 9000kv Brushless Motor for Mamba Max
Price: $99.00
Discuss the Castle Creations 9,000Kv brushless motor in the General RC Electric Talk forum.
