RPM Offset-Compensating Front A-arms for Traxxas Slash
traxxas slash green 70554
The new RPM offset-compensating front a-arms for the Traxxas Slash and Traxxas Nitro Slash not only add about 3mm width to each side of the truck and adds a bit of stability, but the new RPM offset compensating a-arms also allow you to easily mount your favorite tires on rear offset Traxxas or RPM wheels without ever having to worry about different offsets again.
By lengthening the front a-arms RPM has taken the guess work out of which offsets to run and taken out worrying whether or not the wheel / tire has a front or rear offset.
traxxas slash black 70554
Tech Notes: RPM Offset-Compensating Front A-arms for the Slash 2wd & Nitro Slash requires rear offset Traxxas wheels (or RPM #82332 – black or #82333 – chrome Revolver wheels) for the front. Using standard 2wd front offset wheels will widen the stance but may cause rubbing on the body, requiring additional wheel clearance in the wheel wells.
Part Numbers:
#70552 – RPM Offset-Compensating A-arms, Black
#70554 – RPM Offset-Compensating A-arms, Green
#70555 – RPM Offset-Compensating A-arms, Blue
MSRP: $10.95 /pair
Check out more RPM Product News.
