RC4WD Fracture V8 Engine
Doesn’t matter if you’re into Scale R/C or not, the new RC4WD Fracture V8 engine is just plan cool! This is the worlds first scale V8 engine that fits a 540 motor inside. Imagine opening the hood of your scale truck to show your buddies what is powering your truck, then they find you have a real motor under the hood. The RC4WD Fracture V8 Engine houses an electric 540 sized motor. It sends power from the motor thru to the lower transfer case. Then you can hook up either 2 wheels or 4 wheels!
RC4WD Fracture V8 Engine Specifications
- CNC machined billet V8 engine housing
- Fit 540 electronic motor
- 1:19 gear ratio
- Weight: 824grams/29oz
- Designed to fit 32P 18T to 22T pinion gears
- Gun metal powdercoated color
- Engineered by Leo Lipp-Neighbours
- Manufactured by RC4WD
What’s included:
- 1x 1/10 Fracture V8 Engine
- 1x 22 Tooth Pinion Gear
Note:This is is not a functional V8 Engine, this engine is designed to fit a 540 size motor inside.
Part #: Z-S0053
Price: $249.99
Discuss the RC4WD V8 Engine in our Scale RC forum.
