Losi Desert Buggy XL
Losi has released great news for the fans of Large Scale R/C, their newest 1/5th scale buggy the Losi Desert Buggy XL. The Team Losi Desert Buggy XL large scale RC features a 4WD shaft drivetrain, dual disc brakes, aluminum threaded shocks, a 740cc gas tank and a 23cc pull start engine along with a Spektrum DX2E radio system.
Features of the Losi Desert Buggy XL
- 23cc pull start gas engine.
- Machined ring and pinion gear.
- Full four-wheel drive.
- Adjustable servo saver.
- 5mm thick aluminum chassis.
- 740cc gas tank.
- Dual disk brakes.
- Sealed differentials.
- Spektrum DX2E 2.4Ghz radio system.
Losi Desert Buggy XL Specifications
Type:4WD RTR Off-Road Gas Buggy
Scale:1/5
Length:30.75 in (781mm)
Width:19.1 in (485.1mm)
Height:12.25 in (311.1mm)
Ground Clearance:3.1 in (78.7mm)
Wheelbase:22.0 (558.8mm)
Weight:28.7 lb (13.01 kg)
Chassis:4mm Plate, 6061-T6 Aluminum
Suspension:Independent
Drivetrain:4WD
Tire Type:All-Terrain 7.8 in (198.1mm) Diameter
Motor or Engine:23cc CY Engine
Radio:Spektrum DX2E 2-Channel
Servos:Installed
Batteries:Dynamite 1700 mah Receiver Pack
Wheel Size:4.75 in (120.65mm)
Shock Type:Oil-Filled, Coil-over Springs
Body:Panels, Silkdcreened
Ball Bearings:Full Ball Bearing Drivetrain
Fuel Tank Capacity:740cc
Experience Level:Intermediate
Recommended Environment:Outdoor
Is Assembly Required:No
Part #: LOS05001 – 1/5th scale Losi Desert Buggy XL
MSRP: $999.99
Availability: Dec 2013
Discuss the new Team Losi Desert Buggy XL in our Large Scale RC forum or take a look at Losi’s other 1/5th scale RC, the Losi 5IVE-T.
