Kyosho has just released a new high-grade (HG) air filter set. The Kyosho high grade filter set is now standard equipment in the new 777 WC Edition buggy, the Kyosho high grade air filter features a new, high-density foam element and pre-filter. The high-density foam captures the smallest particles to keep your engine in top condition, yet it allows plenty of airflow so the engine can produce maximum power. The angular cut of the Kyosho high grade air filter foam pre-filter creates more surface area, which means the engine will breathe well even when other filters begin to compromise performance.
A molded rubber elbow, filter housing and durable metal inner cage are included. The end of the filter housing even features a mounting lug, so the assembled filter is better supported, which keeps it firmly attached to the engine where it belongs.
The new Kyosho high grade air filter is designed for use with most popular nitro vehicles, including 1:8 buggies, truggies and monster trucks that use .21 and larger engines.
IF345 – High-Grade (HG) Air Filter Set – $15.99
IF345-1 – High-Grade (HG) Air Filter foam elements (2 sets) – $15.99
Discuss the new Kyosho high grade air filter in our General RC Nitro Talk forum.
