The Futaba 4PKS builds upon the successful Futaba 4PK system, offering significantly reduced latency, improved programming sophistication, and the kind of cutting-edge features you’ve come to expect from Futaba. Add in acclaimed 2.4GHz FASST technology, and you have the best 4-channel system around!
Futaba 4PKS features
- Up to 2 times faster than the 4PK!
- View up to 36 functions (including Crawler functions) on the adjustable-contrast LCD Menu screen.
- Wheel position can be shifted using the included adapter.
- A vibrator built into the grip can be used as a lap timer, up timer, navigation aid or to alert you to low battery levels.
- Extra protection features include High Voltage and Low Battery alarms, plus automatic system shut-down after ten minutes of non-use.
- High-voltage, ultra-compact R614FF 2.4GHz receiver included* (*Also sold separately)
Part #: FUTK4901 -4PKS 2.4GHz FASST
MSRP: $499
FUTL7633 – R614FF 2.4GHz FASST Receive
MSRP: $99.99
Share your thoughts about the Futaba 4PKS radio system in our Radio Gear forum.
