Introducing the new RPM Front A-arms for the Losi Tenacity line of vehicles! Designed with strength and durability in mind, these A-arms will take your driving experience to the next level.
RPM Tenacity A-arms are engineered using 30° leading and trailing edges, giving them a sleek, aerodynamic shape that helps them glide over obstacles instead of crashing into them. Say goodbye to those frustrating “incidents” that ruin your day of fun. With beefed-up outer hinge pin support diameters, these A-arms can withstand even the toughest of terrains.
But the benefits don't stop there. RPM has also tightened the slop out of the A-arm, creating a smoother, more consistent platform for reliable camber, caster, and toe angle settings. And installing these A-arms is a breeze! With stock suspension geometry, it's a simple swap that requires very little adjustment to get back on the track.
Made from RPM's trademark blend of nearly indestructible nylons, these A-arms are sold in pairs and proudly manufactured in the USA. Plus, they're compatible with a variety of Tenacity platforms, including U4 Lasernut, TT, DB, Pro, Monster Truck, and T.
Part #: 81662
MSRP: $15.95
