XRAY has just recently released their first nitro vehicle which is, in fact, an 1/8 scale buggy.
Specs:
Dimensions
Length: 482 mm
Width: 306 mm
Height: 180 mm
Wheelbase: 321~327mm
Weight: 3350 g
Chassis
Type: CNC-machined Swiss T6 7075 aluminum
Radio tray and front upper deck: CNC-machined black graphite
Braces: *Rigid 7075 aluminum brace
Suspension
Fully adjustable suspension featuring I.S.S. (Integrated Suspension Settings™ )
Rear supension: lower H-arm with adjustable upper camber link
Front suspension: C-hub suspension with I.A.C. (Integrated Adjustable Caster™)
Damping: *Machined Aluminum, oil-filled coil-over shocks with 3.5mm shafts and rubber shaft covers
Drivetrain
Type: shaft-driven full-time 4WD w/ center diff.
Primary: *steel spur gear / clutch bell
Drive shafts: Hudy Spring SteelTM universal joint
Differentials: Sealed, 6 gear, silicone-filled
Clutch: Aluminum 3-shoe
Bearings: Rubber-sealed
Gearing
Pinion/Spur: 12/40
Primary Ratio: 3.33:1
Internal Ratio: 3.54:1
Final Gear Ratio: 11.79:1
Body, Tires & Wheels
Body: Pro-Line Crowd Pleazer
Tires: Not included
Wheels: XRAY Starburst, standard 17mm hub
Adjustment possibilities
Camber, Caster, Toe-in, Front Inboard Toe-out, Wheelbase, Front Anti-dive,
Rear Anti-squat, Front and Rear Roll-center, Ackermann.
Accessories
Engine: Not included
Exhaust system: Not included
Electronics: Not included
Battery pack: *Included 5-cell 6.0V high-endurance 1200NiMH XRAY receiver pack
Fuel tank: 120cc Capacity with hypertonic tank lid, and internal stone type filter
Also Included
Hudy profiTOOLS hex drivers: 1.5mm, 2.0mm, and 2.5mm
Hudy profiTOOLS Philips screwdriver
Wheel tool
Universal tool for all nuts, turnbuckles and shock clips
Pics:
http://www.teamxray.com
Looks very cool.
Pick one up at: RC-Mushroom
Specs:
Dimensions
Length: 482 mm
Width: 306 mm
Height: 180 mm
Weight: 3350 g
Chassis
Suspension
Drivetrain
Gearing
Pinion/Spur: 12/40
Tires: Not included
Accessories
Also Included
Wheel tool
Pics:
Looks very cool.
