XeRun motor + EzRun ESC?
White_Crow_G
RCTalk Champion
UK Weybridge
Hi everyone.
Just a simple question - can i run XeRun motor wit EzRun ESC?
Motor I'm looking at XeRun-4268SD-1900KV-G3-OffRoad
ESC EzRun Max8 G2S
You would need an adaptor if wanting to run a sensored motor that is not an EZRun G3 motor.
https://www.hobbywingdirect.com/products/sensor-convertor-cable?variant=41032986099827
Hi everyone.
Just a simple question - can i run ExRun motor wit EzRun ESC?
ESC EzRun Max8 G2S
May I ask what this ESC/motor combo is potentially going into?
Sure. it will go in EB48 2.1 (i mentioned it in dm)
also Ez is sensored (i have it in my SSTE)
I just wondering if i can use this ESC with Xe mottor. as i dont really like Xe ESC spec...no BT connection, no 8.4BeC...and more expencive
Have a look at the ESC's dimension specs, and measure the ESC area on the chassis. If you orient the ESC like this...
... it's gonna be tight. I don't know that you'll have enough room to rotate the Max8 speed control 90°.
i currently put my MAX8 with the same exact motor (from my SSTE) its tight, but usable.
But i want to move towards more professional stuff like XeRun motor but just want to make sure it will work with MAX8 ESC
