last nite I started tearing down my Xray and found some interesting things as far as wear and tear.....I started to do a full tear down cause I might get a sunday at Boggy Creek this weekend.....anyway....the center diff wasn't feeling too good so I tore into that...first thing I saw was this plastic shreddings all around the Spur gear where it bolts to the Diff Cup....after tearing everything down so I could take the diff out of the mounts I see a channel just worn into the mount from a screw that came loose and was just grindinga path into the mount...got almost all the way through too......mount was still together though......now that screw let ALL the oil drip out as well and chattered the spur gear into the diff cup and destroyed it.....even w/ all this last weekend I still managed to have a decent main run.....now I'm pretty sure this screw has been eating away at this mount for 2 weeks cause I haven't really checked the car real good in that long and I was getting sparks from my gear mesh as well......just ran it figuring it was gears and when they crapped out I'd just replace em....the diff was BONE DRY...and the gears show no wear on them......all I can say is hudy steel is DA poop.....although I did break an A-Arm and bend my front shock shafts.....this thing is still a tank in my book......just had to give a shout out for the XB8
