would this fit a 2.5 trx
It will not work well, first it is rotary and you have to modify the car/truck and I believe the opening is smaller too.
No, the neck is smaller OD than the 2.5. I only know of a couple alloy ones that fit the 2.5/3.3 engine, both are OS carbs, neither were/are cheap. One I can't remember the model, the other is for the 21TM/18TM/18TZ. OS 11K, the 11K-R was for the revo, only difference is the arm for the carb slide is straight without a ball on it.
https://www.towerhobbies.com/product/carburetor-11k-slide-18tz-21tm/OSMG3665.html
It doesn't really make the engine perform better, but it will hold a tune all day long.
hey, i was mistaken, we used a force carb, which a torq is nearly the same, made by force. Torq is all aluminum where as the force we used is black composite middle, which is better as all aluminum heats up the fuel more
