militarymaxx
After completely dis-assembling my stock B01 Storm engine, I wanted to see if I could save it. This is what's wrong/damaged:
-front bearing slips in/out of block easily (lots of slop)
-no compression at all
-piston and sleeve scored deeply (piston/rod clip missing)
-pitting on top of piston (residue front piston clip I think)
I think that the piston/rod clip came loose during a run and that's what caused the scoring. It was my first nitro and I struggled with the tuning. The temps and revs got too high too often. So I think that is why the front bearing slips in/out easily. I may have just damaged the bearing or even worse expanded the block. If the block is damaged, then I can answer my own question and trash this thing. If it was just a bearing, piston, and sleeve that I needed, is it worth saving ? Thanks.
