There's no such thing as a dumb question when you're new. It's only dumb if you don't ask, and then damage the engine.
CB is the clutch bell on the front of the engine. Inside there are shoes that spin out against it when the RPMs come up.
The teeth on the front of the CB contact the spur gear. The spur is a tension contact with the slipper clutch. When all that is good, the engine will turn the transmission.
There's a nut in the center of the spur gear. Tighten it down, then back it off about 1/8 of a turn.
Start the car and let us know what it does.
By the way, taking the engine off and bringing it to the shop will not help. Hang in there, we only need to isolate your problem.
