Ok, so while I'm breaking in this brand spanking new STS .30 with the heat cycle method, I hit the throttle less than halfway, let go, then hit it again, and let go, and then suddenly it won't rev down. As if the idle gap didn't go back -- but I'm pretty sure it DOES go back, yet it keeps revving at high until I hit the brakes.
This happened earlier in the break in cycle as well, but stopped after I loosened the LSN a bit (Screwed it out.). Any idea what it could be? A leak where the idle screw is? But it stops revving after I hit the brakes.. So, it does sound like the idle gap simply isn't closing, but last time I checked, it did close yet it revved high. Is it possible that it's slightly open, and since I'm running it with the wheels in the air, it gets stuck in 2nd gear and revvs high? I dunno. It should go back to idling, but it just revs high.
And since it goes back to normal idle once I hit the brake, I don't think it's a leak anywhere (Would be the carburator screws I'm guessing -- since it happened and stopped after playing with the LSN at a certain location, then again when I opened the idle gap a bit. Haven't tried again, since I had to screw the engine screws tighter. Unrelated issue.) -- or am I wrong?
To break it down, why doesn't it go back to idle when I let go off the gas, and the idle gap goes back to almost closed? I didn't get to check whether or not it went back to normal (Almost closed. Normal rev.) this time, but last time the idle gap went back to normal but kept revving high (And I'm sure that the idle rev is OK/normal.)
What could this be caused by, what should I look out for?
Just went out and tried revving it a couple of times, and it is normal now (After I set the idle gap screw back to normal/previous location.). Is it possible that a certain combination of screw locations could be letting in some air in the carburator, resulting in this? But if that was the case, I don't think braking would do any good since it would still be letting in air. I have been having lots of issues with the electronics in this though, but I think that was caused by the battery wires. I used to loose connection constantly with the car. Using another battery now of course.
