Which tires do You recomend? For an arma mojave 6s
Tamiyalover123
I have had My arrma mojave 6s aprox 4 months,i usually run the car of 75% power(6s battery),but the tires are so so bad, in special the rear tires.
Which tires do You recommend me (type and brand)?
Also,What do you recommend me to avoid fast wear?
Thanks to read : D
Are you running on dirt or pavement? Makes a little difference in what people recommend. I used the stock Fortress tires and never had issues, but I mostly ran it on hard pan covered in a layer of soft dirt.
If your running mosly hard surfaces look for street tires.
I usually run on grass or dirt, but rarely on pavement.
Stick with the Arrma Fortress Mojave tires. $77 dollars for a full, new set on Jennysrc.com when they available. Or try the Aliexpress $30 ones & maybe the rims hold up a while. I have read that some Aliexpress tire/combo/rims, they crack, but this was feedback from a big Kraton & Notorious basher.
Or here's a new set---
https://www.ebay.com/itm/1267374399...q7FPNHENTvG&var=&widget_ver=artemis&media=SMS
Another thread about some---
These are still going strong, I use them on dirt too. The plastic wheels seem flimsy but I haven’t broke them yet.
I wacthed the 4 wheels in amazon to 66 dollars,the tires have good revises,it is similar to the Aliexpress,but in My opinion theses of Amazon look better than the others tires (Aliexpress).👍 https://a.co/d/cC0MhIu
I believe those are the same ones that they sold on ali, I got the street looking tires, those right there were the other option. I would try em, I bet they are decent. $65 for Mojave tires is a good deal.
