WickedFog
Community Leader
RC Showcase: 9
- Terre Haute, IN
- Crawling
- Scale Builder
So dirt gets into your diff case, and then inside a sealed bearing?You can go significantly longer on the hub bearings, but still a good idea to inspect regardless, the diff bearings absolutely need to be repacked every 2 hours if running on dirt, you can get away with longer run time if bashing on the street with no dirt present... it will take some trial and error to figure out a solid cleaning interval that works for you... 2 hours has been a necessity for my program for many years and I haven't had a single failed bearing yet.... I see failed bearings at the track all the time, first question I ask is when was the last time they cleaned and packed their bearings and I always get a response along the lines of "I didn't know I needed to clean and pack my bearings with grease", doh!
