Which plug should I use for my Trx 3.3 engine?
:D lmao
Sweden
  2. Scale Builder
I’m running a stock 3.3 engine, and I’m switching to 16% fuel, question is, should I use a different plug to adapt to the new fuel I will be using? (Currently running stock plug and worked perfectly on 20%)
thx
If it doesn't work well try an OS LC3
for better idling and good acceleration throughout the throttle range Compatible with Traxxass EZ-Start system Hot heat range for fuels with 5%-20% nitro content No idle bar
If your fuel has a higher methanol concentration (less oil and nitro), you will want a glow plug that will react less to the methane during the catalytic reaction in order to have the coils of the plug to produce the necessary heat to reach ignition temperature at the correct time.
Plugs that react less to the methanol are called hot plugs.
