WickedFog
Community Leader
RC Showcase: 9
- Terre Haute, IN
- Crawling
- Scale Builder
You might have to fab your own links. LGRP has some link ends here https://littleguyracingparts.com/products/builders-rod-ends?_pos=3&_sid=bc41950ad&_ss=rI added brass rings to the FMS FCX24 Blazer wheels. I also put the stock Blazer shocks with oil added. Unfortunately that's about it for leftover parts. None of the original or spare aftermarket FCX24 links fit.
Here's a vid on how to make them
Sounds similar to what I initially did to our SCX24 C10. And the steering linkage binds up on the stock SCX24's as well. If you have some small o-rings, you can put a couple under the link bar (around one side of pillow balls) and it may help keep the steering link from flipping around and getting hung up.I trimmed the lexan body right below the grill to straight across the front of the fender. This gave steering clearance for the front tires. The linkage still binds up but not too badly. It's already WAY better than it was. I also removed the plastic luggage rack on top and the spare tire on the back. Stickers removed and stuck inside the body for posterity.
It's weird. The darned thing is fun for what it is. I would consider these 'must mods' to make it somewhat capable.
Very interested in seeing what you do next.
