what will happen if i drop a venom fireball 17t motro ina dutatrax evader st
toolmakerman48
RCTalk Champion
  1. Racing
will that work? will the esc be ok because i already bought the motor and am breaking it in now
As ling as the ESC is rated to run 17T it'll be fine. I don't know what kind of speed control you're running or if it's stock but I'm not familiar with the specs to say for sure. check on the specs for the ESC. It needs to be 17T or lower.
Are you gonna look into it or just wing it?
I'm at home now so I can look it up real quick. BTW- this took 5 seconds using google and Towerhobbies.com :thumbup:
If you are running the stock ESC (Sprint 2) then it's rated for 20-27T motors. You shouldn't use that fireball motor without upgrading your ESC. I'm sure it'll work, but I can't imagine you WON'T burn up the ESC eventually.
thanks alot for looking it up. its a sprint 1 esc not a sprint 2. ill watch the temp to make sure it dont burn up.
