What the hell happened to my hump pack???
Domination
Well i was just out using it and all of a sudden my fail-safe kicked in and couldnt get any response so i figured it was just flat dead. But i got to plug it into the charger and its supposed to beep when you plug the batt in so you know it detected it but nothing happened. And no its not the charger cause i tested in on a pack in one of my other RC's and it worked fine. So is my hump pack just dead for good or what? It doesn't look like anything broke inside because i cut the shrink wrap off and the wire looks fine and the connector bar things look fine. So what the hell happened to it?
Check the wires with a meter.
Check the switch if you have one.
Check the connectors.
Check the batteries with a meter.
Its rare that a hump will just flat dye.
**Most likely there is a brake or short in a wire, connector or battery bar. Just need to trace it down with a volt meter.
alright thanks for the info ill do those things and hopefully find the problem.
