What size hex does proline badlands mx28 use
The MX28s use a 12mm hex which is typical of SCTs. The Granite uses 14mm hexes. you're going to need 12mm hex conversion kit for the Granite (If they make such a critter) or you're going to need some sort of adapter to run those.
Pretty sure if they are the later model mx28's, they come with 2 adapters, narrow and wide 12mm hexes you can swap out. They also offer 14mm ones, but only see the "wide" offset version:
https://www.prolineracing.com/product/1-10-6x30-to-14mm-hex-adapters/PRO634700.html
They also offer alloy versions and 17mm versions:
https://www.prolineracing.com/search?q="PRO1012510OptionalParts"&relationType=OptionalParts&parentProduct=PRO1012510
Thats good info! Thanks Olds
