what model is this?
avelciario
Hello Guys, can anybody tell me what brand and model this truck, please help. Cause I want to rebuild this.
Yes, I think so, caused it gives me very hard time to get the spur gear, I am not sure if this is what they called .8 metric pitch spur gear and cluctch bell. Any other chance to change the spur gear and clutch bell with different types of gear pattern? the shaft is only 4mm size.
I bought already new LRP Z18S Nitro engine to replace the old engine.
Thanks for the help Mr. Bones.
The teeth will look thicker on a 0.1 metric pitch or like a revo gearing and they only offer up to a 40 or 42 tooth spur from what I've found with the 0.1 pitch and 14 to 17 tooth bells. So with that 2.5 black transmission i dont think you can change the gearing pitch. And yes that is a 2.5 transmission with reverse. All of the newer 3.3 are grey and forward only.
Wow! Surprised they havnt been sued for knocking off the tmaxx on that one! Looks identical to the 4910.
the chassis is different this is NOT a tmaxx
---------- Post added at 11:24 AM ---------- Previous post was at 11:22 AM ----------
also look at the radio box, NOT Traxxas
---------- Post added at 11:24 AM ---------- Previous post was at 11:24 AM ----------
also look at the chassis were the engine mount goes........not a t maxx
Snookman- Yes! its same what you are saying, even the old engine same, all the parts are same. Now I am sure what truck is this. Thank you so much.
So where I can get the Spur gear and clutch bell that can fit to this truck. The teeth are more closer to each other (fine teeth).
