- Baltimore
- Racing
- Crawling
- Scale Builder
Heres the problem. Motor over heats and I strip spur gears.
1. Gearing: As of last time I ran the MTs. I was running 14t pinion and I believe the stock 86t spur. Should I go all the way down to a 12t pinion?
2. Stripped spur gears: This can also be the gear mesh and the slipper clutch. I use traxxas recommended settings for setting the slipper. How loose or tight should the slipper be? Traxxas recommended setting is 1 full turn from fully compressed. Traxxas recommends on high traction (road and street) to be 3/4 turn from fully compressed. With these MT tires I plan off road in the field and some sidewalk.
3. Motor over heating problems: I have a HW heatsink and fan but it will not fit due to the transmission case. Might have to customize the trans case to make the fan fit. This is the HW fan I have: https://www.amainhobbies.com/hobbywing-c1-motor-heatsink-fan-combo-hwa86080120/p279174
MT tires I have: Duratrax Lockup MT 2.8 (12mm hexes)
Car I'm using them on: Rustler 2wd with HW max10 (60A, sensorless) with 3652 4000kv motor
Gearing I have right now: 23/86
Gearing I had for the MT tires: 14/86
Gearing I plan to do: 12/86
I already got new tires for the slash and I have these laying around so why not use them.
I am also going to look at the Stampede 2wd recommended gearing and slipper settings because of the 2.8 tires but these are 2 times bigger and probably heavier than the 2.8 Traxxas talons from the stampede 2wd.
