RC MAN
RCTalk Qualifier
- Thread starter
- #21
Those 40mm fans definitely work. They have to sit away atleast 5mm.
By the time you add all that weight, the motor is going to be under a ridiculous load and will likely run even hotter. It would be far cheaper and way more practical to just buy a motor and gearing more suited to the application. The whole idea of this is well, just silly.
Thanks guys for the info!Water jacket for a marine 540 or 550. Water pump, radiator, and fan. Can bleed it like a computer closed loop system. Have to run distilled water as it does not conduct electricity in case of a leak and maybe some computer water wetter for pump lube and corrosion inhibitor. They also make passive radiators that are small. I’d source a rc excavator rad like this
https://www.ebay.com/itm/284553503145?chn=ps&_trkparms=ispr=1&amdata=enc:1nZGBvK-RQTW-lCw7-djdaA39&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=284553503145&targetid=1599090335177&device=m&mktype=&googleloc=9016800&poi=&campaignid=15275224983&mkgroupid=131097072938&rlsatarget=pla-1599090335177&abcId=9300697&merchantid=421393394&gclid=Cj0KCQiA09eQBhCxARIsAAYRiymM-r4iwCcQZPb6if9ggVen7_OtTNczn3sEFHYTJLhpTEdx8BubzzkaAvPiEALw_wcB
Check out primal rc’s website. They have a electric conversion kit for the Raminator you can look at. Way to big for a 1/10 scale but you can see how they made a working system.
Or grab a 550 marine can with a jacket already. They have multiple sizes.
And everyone thinks everything’s a dumb idea til it works. Never listen to anybody about trying something out because you’re interested in it. That’s how progress and innovation are achieved.
Now, for me to even attempt this i need some more beefy shock on the car i planned to do it on.....
So me being stupid decided to buy some shocks from a arrma senton (which weighs about the same as the calculated weight for the car i would like to try it on) but then soon realised that they were way to long for it and made the ride height rediculosly high and made it so the chassis when fully pushed downwards couldn’t even touch the ground but remain about a inch of it. (which apparently is bad)
So i am now looking for 90mm shocks that should definitely fit it and i found a few that are meant for crawlers. They are meant for a trx4, km2 and a d90. So that means if they are meant for a trx4 which weighs about 3.3kg and a d90 which is about 2.3kg, they should be good to support around 3kg of weight which the car should weigh with everything in it.
Does it matter they are crawler shocks (because i can add some thicker oil to them) and also which one out of these shocks would be the best for my application?
1
https://www.ebay.com.au/itm/194839254541?_trkparms=ispr=1&hash=item2d5d53160d:g:s4oAAOSwxc9iDMON&amdata=enc:AQAGAAACoPYe5NmHp%2B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSd3M8ngECaRA0SmyU4KT%2Fnk7%2BKYT5qiqLB0eqyA7foL2OGygTD%2FSn2O6X1UKBLQoSgSL30G3VzlCtxBGaK40L5JhYWGo%2F6jrvQ7sqF4F%2FhayWqXcXkwfNs2xFdbsK2wsmCzMdKbBtPmrshD1g1EMjXIUHegFfg60qm9QUt9iRUl7g24TghvYxCmmNjIbqPOMsDykOJLA3gRl0Z91INHcUIIxT2oimOtuWKwM0XCNwVHzEgCeCIZnJwIuDlnsuKYTOvegaJJqoji4dlfl%2Bv0tWLRDKwg%2F0fcEpL%2FX6Cl%2BeuufLN6DzbSgWwUXsqdiYHs9bb99OfzYKmX31Td%2BFsa7rQ8y6JjJPNKpUV8T8ofpS57IeyR461Z2Yb0MdCicXNxQZnTTjmc%2FwMTDH0iZYQ9kWfW%2Fkuv%2BiXYJ3ZGDTs2SFED8DWvo98b0rT%2BDCAsQX1eJoppU7a44nWAULBnv4L4LZ5JAuKoXLwsnyZO7oS9bLY8WYZ6THXxZ%2B8xmfj7HyujMLTn9HKov4dvXaeJzQ%2FpXuH05nBHoTNzC7mhFk4isxPMf%2BRG8OdaScbGYqRGkDcdm1CwlsCc8KFF3YbfbPfJgcTzBQeuS17BJ3L9Eu7D1Sar%2FuGm7I1y%2Brq9MSoJOn401pCrjSTsaiZGbt1AOZ25dNAkCRzHDAXDQ%2BQw3zCayH9CzhDEtwnJBQxf%2B%2FuVZyXtCx3Z339mBtiD0Xy0oRegQXpo%2BjoymJAn0ex3lscq0vA4r8ld7JDrmoThMPUaJagnOfjhLncAN0fArSaGLiAfRSKNkWC3wnVnNDFCTKuhF5BpgoUCPGMJBLmsPLo8SK9f8jzrFhLTmY4%2BRo1aYcZmiHOQ%3D%3D|clp:2334524|tkp:BFBMzqbmjORf
https://www.ebay.com.au/itm/353743058450?_trkparms=ispr=1&hash=item525cbab612:g:2S8AAOSwv11hd6b~&amdata=enc:AQAGAAACoPYe5NmHp%2B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSd0ReTLyM7cxPnI6zs468EIJ0XPw6ALOqtDWRgvH4OyOtLxHRMFPja%2FsFSUW3IHGQpg9BsfAIXOjVpNihgxyq6ybLJEgkyTbR9IDfSIPDwM1VTUs2zt6gYMMdEPGqhMzCLTRglasEiFPISkKJjNQdghVAkiUADZDBiCBlQ%2BXR%2F6LJsvF6xmwsKrkhHjgqr%2F2nvYgFjnX4HZfoIiXxreGAx1HJM97VsgnhxbLLNcMdtXWX2EY%2B7sRW6yj0mmlCC7H%2FyKAPXLdfyulpYa0hVt6tmhLTEcrt0%2BAPXhCF8rZ9uRATWGASlHxQCgGNpHCmbixO8sB2eJT9vZvdvI%2BXFO%2BFNv7qITKkdSrma%2Br40h4T3ylwjqdLCg6R0DAQe8YbMAdLgQBhaKJ0hwwWam8P1jTcdmoTD4WDJaZcGHgKCIqSZXW1RyiDvhWKEbDXRzbQcHxfi7n%2FnS%2FSaodbLz4Z7fKC%2BHOOnm7MtWxtHu2eZg5auBQCQaFTlU6gS3gFqqlboyWgrjR7xbaNsG8p02YM%2BIzxWOEloWCp3bT65hc43tMUPQjJjPP2N5y7paQ845dhUIKwnbzlgR0zAgWriCU4Lxu077cZZxzu0RIT8QvmTAg%2Ff3z2Yz9E4wv6y4vkf9D2XDSarTgJ8lVW5tgIf29gRTzKvXps%2Fpz5Yl4OukYVrAyVxSVXxIb396x9yXTebp%2BAToWmGUB7l17iRwwZuLt1vIG3MQ2PzZZC8NyyBxJDR2br9cRaPliVNWtxpPyGxN1JOBNSY%2FgIHXkMOKIUoHqQmCkPJgXe59I4Nj7msWnQM0YdobMZ21ihpfzQB69YbpXO28T%2FE%2F0aGv0McZ2coBPI0WTxvw%3D%3D|clp:2334524|tkp:BFBMwJztjORf
or 3
https://www.ebay.com.au/itm/334165842300?epid=14045618924&hash=item4dcdd6197c:g:0FQAAOSwlnxhVdYS
Cheers,
