did you tach the 42,800 rpm under load on the wasp28? Or does just feel like 42,800 because it doesn't spin any faster or there's no more power? Yah, sure the wasp26 says it goto 38,000 rpm but it makes less than 1 hp after 28,000 rpm and the engine won't pull any revs after 30,000. So what is the max 30,000 loaded or 38,0000 under no load.
I don't doubt the wasp28 has more power than the 26. It probably does but the 26 has more going for it. It's a better built engine and from what I can see from having both apart the 26 is more durable than the 28. Which will be more dependable a more powerful engine built weaker or a slightly less powerful engine built stronger. If you ever decide to port/polish and/or have it modified to make more power which engine do you think will stay together and/or not wear out fast.
I don't have faith in my modified wasp28 lasting too long sure it makes crap loads of power but the bottom end is weak. For example whren grinding the crank it took alot more time to take material off the 26 crank than the 28 which means it's harder and stronger. Under increasing loads the 28 crank will fail (snap) before the 26 crank will.
