wandering to the left
Lt.Doomsday
RCTalk Racer
i just noticed this today.the R/C car won't stay straight and goes to the left.i've tried setting it using the steering trim.it helps a little but not much.
i've checked to see if anything is loose that could be causing the wandering,but everything was tight.
anyone else know what the problem could be?
Sometimes my storm my do that after a damn riff landing and kinda back the screw out thats holding the servo horn on. Ok take the screw out of the top of the servo and pull off your servo horn. Now cut on the receiver and transmitter and set your trim to zero. Then straighten your wheels as much as you can or have someone else hold it like that that and then put your servo horn back on and put the screw back in. And that should make it btter and then adjust trims as you see fit.
Originally posted by Lt.Doomsday
so it will have to be basically reset back.i'll do that tomorrow.thx
No Problem. Yeah its basically a reset, I have to do mine every two weeks atleast because land so hard so wrong some time. Only cost ya about 2 mins of your time too.
