Venom creeper differential
alloffroad
A while back i bought my daughter a venom creeper. Since then the front axle shaft broke and the differential seems to be broken. I think the spider or planetary gears are stripped. Does anybody know if i can replace that or, which is probably the case, can i replace the axle as a whole with another brand.
HERE is a link to the user manual that has all of the part numbers in it. Find out which parts you need and then see if you can track down the parts using the part numbers.
There are a fair number of various crawlers out there that are similar in design so its probably possible to fit axles from a different rig on it but if so I couldnt tell you which ones. Maybe some of the others with more crawler experience can answer that specific question.
