Personally, I keep carb cleaner away from RC. It will destroy a body in seconds and probably isn't great for any of the o-rings in your engine/carb either.
I take my carbs apart, clean with DA and a q-tip. I clean the outside with DA and a toothbrush, then rinse everything with water. If you want to clean the inside of the engine, you have to take it apart, clean each part however you want, but he coat everything with a thin oil, usually after run oil, or it will oxidize and/or rust pretty quickly.
