Underdrive micro servo selection for SCX10 Pro reccomendations?
ferrebee88
60% of the time it works 100% of the time!
Military Veteran
Build Thread Contributor RC Showcase: 5
Gig Harbor, WA
  3. Crawling
For those of you who have installed a micro servo for the selectable underwrite function of the SCX10 Pro...
I recall the 10.3 and the ryft needing the spectrum micro servo, but i don't want to go down that rabbit hole again.
I would like to get a reefs micro 99, but I can't find much info on the install of it and if any extra parts are needed. Any info from experience would be greatly appreciated!
I'm using a reefs micro 99 and the servo horn with the slot in it, provided with the scx pro kit. Takes a little bit of fiddling to get the throw/trim sorted so it properly engages and disengages the underdrive, but works great. I found that it will click over to push the shift rod into the trans, but won't seat until the truck has moved forward/backward a bit.
Awesome! Thank you. I'll pick one up at some point.
