Wow, full of questions this week, you can tell its almost spring
I have the truck completely torn down, de-anodized the chassis and have been working on polishing it. In doing so, I noticed that if I put it on a flat surface (table, counter, etc), its not completely flat. There is a little "play" in it, almost like its warped (like you can push one edge down, and the opposite corner ends up off the flat surface).
Question being, is this a bad thing? I figure the chassis braces, bulks, and skids might straighten it all out, but just wanted to be sure.
After seeing this, I looked more over the chassis and it almost looks like the front bulkhead "tabs" might be bent upward a little. I'm not sure this is wrong, because it would be a large coincidence to bend both of them up the exact same amount, without making the metal around them look weird, and without snapping them altogether.
Id like to know if the chassis should be replaced, while everything is torn down (and before I waste more time polishing it
Thanks!!!
-Chris
Thanks!!!
-Chris
