Originally posted by Easy-MAXX
thanks for that offer it is the best one so far,over on traxxas i posted the same Q,must have been too technical for them,i got no replies at all.
You reminded me of a test I had to run at work for one of my bad apples who claimed to have bad hearing but heard wispers really well. Anyway, he got the DSoctor to keep him away from high intensity noises, anything about 87.5 db on the A scale. Not wanting to deprive him of some good clean fun at work I had the test done and found exactly where he would hit 87.5 db at the work place and he was not going to be able to be kept miles from work like he wanted, only 20 feet which meant there was little he could not do at work. Next the guy got another Doctor to say he couldn't walk long distances but that's another story.Originally posted by Çh®i§tiªñ
Can you explain a little bit more? Like, what the purpose of the test is. So I can see the whole Scopy of the analysis. As well as what needs to be tested and/or what vehicles.
Decibal tests are pretty simple if you have the right equipment to test with. The key to decibal tests is making sure you are creating the loudest noise possible to see the extreme. For instance, you want to open an outdoor track and the most # of vehicles running at once will be 15. Then you will need 15 vehicles hauling around and test decibals in ALL directions. Starting trackside and moving out as far as 100 yards in some instances.
Follow?
