Trx4 and snow
LowCountryCrawl
  1. Crawling
So it snowed and I took the trx4 in the snow, any special treatment for all the caked up snow under the body? I put it in the tub sitting up to let it drain.
Much better to blow it all out with a low pressure compressor if you have one.
A shopvac with the blowing out also works.
It's bests to get the moisture out as quick as possible, I wouldn't let it sit wet.
You can hit it with water to melt the ice. It's already wet. But don't hook a battery up to it again til it's completely dry. And WD40 can help dry it out faster.
+1
Use a paintbrush or something similar and get rid of the solid snow/ice. Then place it upside to let it air dry.
