Hey Guys,
I've been screwing with my savage after about 5 years in the shed when the starter pin broke for the 2nd time. Just when I think everything is running perfect, it will act up on the next tank. Then it will bog under heavy accelerating and I have to adjust the carb. My biggest problem is starting the damn thing. Sometimes it works fine, then sometimes it is a 1hr waste of time. It always takes me about 10 minutes to get it running. It was running fine and I was doing some fine tuning, then I filled it up from a half tank to a full tank and then spent 30 minutes trying to start it before I gave up.
I'm using a d battery glow plug starter and I notice that it seems to kill the battery really fast. If I have the glow plug hooked up for more than about 10 minutes it seems like its not working well and the voltage goes from about 1.6 to 1.4 (on vom, not the crappy gauge) and when I remove the plug it looks like its not glowing enough. The top coil hardly ever turns red when I have the plug removed and in the igniter . I rigged up some pipe so I could stuff 2 D batteries in there and it starts WAY better, but I kept screwing with it to get a good connection. Sometimes I have to use a torch or heat gun on the heatsink to get it to start. My next plan is to get a 4 D battery holder and run 2 in series, 2 in parallel, with a harbor freight VOM attached to monitor the voltage and a remote attachment for the glow plug with a switch to turn it on.
I'm not new to tuning, just new to nitro. I tune mustangs on my dyno as a side job and would say that I could tune 5 supercharged mustangs in the time i've spent messing with this truck to get it running correctly.
I have some questions that hopefully you experts can help me out with before I sell this POS and buy a brushless truck that will actually work when I want it to.
1. How long does it typically take for you to start your truck?
2. How many minutes would you estimate that a 1 D battery glow plug should last while its hooked up?
3. Are there better glow plugs that run hotter?
4. Is it typical to have to mess with the tune every time you drive it?
5. what percent of the time to you spend starting and tuning, vs driving and bashing?
My nitro fuel is less than a month old.
The engine has about 5 tanks of fuel run through it and the compression feels strong.
I use the electric starter with a fresh battery or my dewalt drill if it dies (the starter spins it way faster than the drill)
Once its warmed up and running it idles and starts back up just fine, but if I wait a while it gives me crap.
