Build Thread Trophy Truck One Off Build
it ll get slash wheels, they should be here tomorrow or friday with the Wp 2075 servo as well.
thanx for the props. i was expecting a much tougher time of it, but things seemed to fall inplace for the most part.
slash wheels and 2075 servo showed up today, so on they went
This is just sick! I really want to build one like this! What is gonna be the grand total spent when it is done? And what system is gong into is a mamba max?
xxx roller was 50.00 i got the 2075 servo and slash tires for 31.00 shipped (all 3 ebay deals) the rear shocks cost me 12.00 and the fronts were also 12.00 (also both ebay deals). i have a slash esc/motor combo comeing from Savage Fan for it too. (deal from here). so all thats left is a body, way to mount it, and likely slash front hubs and spindles that will need to be modded on. 25.00 for the WK Axle.
so all in all, once running, i d say i will have just over 200. i ll be useing my React system on it for radio.
thats looking great timmahh!!!
now i wish i hadn't tossed that duratrax ST i had.. lol I still got the shocks though. maybe i will try my hand at a one off build. I need to finish the radio shack to hobby electronics build first though..
ok up date time.
I got the Axial HD Lower links here, and got them installed this evening. I also modded an Axial battery plate for a battery plate on this. i think i may need to relocate the upper 4 links toward the middle of the chassis a bit more now that i have the Axial HD links installed. they pulled my WB in about 1/2 of on inch so it now runs rigt at just under 13. i may also just redrill one hole, and move the lower chassis link mounts back a tad which would likely be the easier and better method to recorrect the wb to 13.2 inches. I also think I'm going to need the blue springs on the front Axial shocks with abit heavier oil. now that i have a servo, and the battery up front, its abit too soft, but i ll start with some 50w oil or something a bit thicker.
I also picked up a set of Slash front carriers and spindles now my front wheels are free wheeling and smooth rolling. i had to take just a smidge off the inside of the carrier to allow for the spindle to turn thru the carrier and not rub. so far so good. for shits n grins and to see how it moved, i put my rooster crawler setup . didnt go very fast with the 55t motor, but i drove it. lol
also installed a Slash waterproof radio box. should have the xls and 21t slash setup in the next few days. down to a few small mods, a body and getting it mounted for now.
few current pics.
Looks like your progessing right a long, are you going to lower the rear or rais up the front to level it out? keep the updates coming...
once i find and install either softer springs on the rear, or remove those spring and mount a 2nd set of rear sprung shocks on it, it should level it out some. i ll also be putting the stiffer springs on the front shocks to keep it a bit stiffer up front.
got the xl5 and motor in today (thanx SavageFan for the quick shipping too!), so i got it installed, moved the trailing arm mounts back a tad, installed a 2nd spacer in them to make them swing more freely, and added the blue springs on the front shocks. is just a bit bouncy up front, but i still need to remove the stopper inside, and redo the oil in them. ready for a body now and a place to mount it. then ill be basically water resistant and ready to go.
i wish someone would build these type toys to sell to us serious bashers,so what if we paid a lil more,ad up all your spares
