BEC is short for battery eliminator circuitry. It's the ciruit that powers the receiver and steering servo. Back when electric rc's had resistor speed controllers, they needed a seperate battery to power the receiver and servo(s) just as the nitro's did. When the esc, or electronic speed controllers hit the scene they had a circuit built into them that "eliminated" the need for a seperate battery to run the receiver and servo. The output voltage for the
BEC is adjustable in most esc's nowadays. The higher the voltage, the more power we can get from our servos. That is as long as the receiver and servos are rated for higher voltage.
TRX is a bit outdated in this segment with only 6.0v
BEC. Even Spektrum rtr stuff is running 7.4v these days..as is most aftermarket esc's such as Hobbywing and Castle. They can however bet set to 6.0v BEC to be used with stock receiver and servos such as TRX.
Yes, the
Max6 is basically plug and play (after soldering connectors) with the stock E Revo motor. You'll have to either buy a mount (ebay), or use double sided tape to secure the
Max6 to the Revo chassis. My brother used Gorilla brand tape, has held up just fine. You'll need to program the throttle range when you install a new esc. Pretty straight forward though.
If you want to stick with a VXL6S, I believe Jenny's rc has them for less than retail..this would save you from having to solder connectors onto the esc wires. I don't know what connectors you're currently using but many prefer not to solder. Up to you.
https://jennysrc.com/search?type=product&q=VXL-6S
