Traxxas Slayer pro won't move when on the ground
Jpslash667
RCTalk Qualifier
Baltimore
  2. Crawling
Ok so when I hit the throttle when it's on my stand everything is fine, I put it on the ground it won't move. It worked fine for the first few minutes I ran it. Any ideas?
Lose slipper, damaged pegs on slipper if old style, broken tranny gear or sheared pin in tranny or a screw backed out in the tranny.
You can check to see if it's the slipper clutch side or engine clutch side fairly easy. With the body off watch the spur gear when you try to take off. If it turns (or spins) the engine clutch is OK. Then try tightening the slipper clutch up.
(You can check to see how tight the slipper clutch is by hand. Put a small Allen wrench or something in the hole on the input shaft sticking out the back of transmission to keep it from turning. Same shaft the slipper clutch is mounted on. Then try turning the spur gear. It should not turn too easily)
What if the spur doesn't turn at all when I do that
Ok so update. Sooo I have the dynamite .19 on my rig, I noticed the plastic piece that grabs the throttle off the servo is broken and not fully opening the throttle due to it falling off when I fully open the throttle. So here's hoping it's an easy fix and I don't have to dive deeper
Sounds like you have a loose slipper, busted the primary shaft inside the trans, or broke the threaded pin on either the output gear or the input gear. I have done all of these things, except the slipper being loose, and it causes that same issue. Engine will spin the wheels fine fine until has a load on it
update, traded the bitch for an electric. Nitro isint for me lol
Nnnooooooo........ losing everyone slowly but surely....
