Traxxas slash 4x4 ultimate
Matthew123
  3. Flying
I Want to turn my traxxas slash 4x4 ultimate into a race rc short course truck what would be better for esc and motors for it that is brushless
Hobbywing Max10 G2 sensored (140A with a 3665 motor)
Hobbywing XR10 Pro with your choice of motor
Hobbywing XR8 with Hobbywing 550 motor
Tekin RX8 with Tekin 550 motor
3000 - 4600kv range ? (questionable)
Will you be running normal 2s for a 1/10 indoor track, or 4s (mainly meant for 8th scale) on an outdoor track?
What surface?
Budget?
If 2s, the Max10 and XR10 options will be best. For 4s an 8th scale esc with a lower kv motor will be best. The Max10 G2 can also run on 4s if its the 140A esc with the 2400kv motor only, but just watch temps.
I run a Max10 G1 SCT 120A sensorless with a 550 4000kv motor in my slash 2wd. I raced it a couple times and it was alright. It was sensorless tho.
Back in the day when my uncle was into RC, in his 4x4 SCT (Losi SCTE and TLR SCTE 2.0) he ran a Hobbywing V2.1 mainly, and he ran a XR10 Pro for a little bit, with a 550 4.5 Novak motor. It was a beast, but now those motors are rare, found a few on eBay going for around 150 bucks +, insane.
I was also thinking about getting a Slash 4x4 Ultimate, or the new BL2s but roller off of eBay, and start a little cheaper project, slash 4x4 but for racing, I like my 2wd, but 4x4 will be better for me (more controllable in the air, more grip in the turns, and the local track only runs 4wd)
Slash 4x4 chassis is a bit compact. So not sure if a full 8th scale esc and 550 motor would likely to fit in there compared to what is normally in there RTR from the factory. (Not as spaced out and open as a SCTE or SCT410)
What surface you gonna be running on?
Outdoor dirt = softer compound mini pin like tire
Indoor hard packed / sealed dirt "clay" = bar tire or slick with traction compound
Indoor carpet= harder compound mini pin or wedge tire
Turf= Same for carpet, or bigger lug / knob tires
On my 2wd, I run DE racing wheels, I like the Trinidad ones, like the design.
I run Schumacher Mini Pins front and rear for indoor carpet (mix of black crc and grey eos) I might try Fuzz bite / Swagger or Pin Down / Swagger in the future.
I run JConcepts Smoothie Greens front and rear for indoor sealed dirt "clay" with traction compound. I been using FDJ Yellow dot and its been pretty good.
But tires are different from car to car and track to track, so I would talk to the locals and see what they run. ;)
Edit: 10th scale esc and 540 motor can also work if space is an issue
I'm going to save you a lot of time/money/frustration.
Step 1) Sell your Slash
Step 2) Go buy a TEKNO SCT410 2.0
I no longer race the 4WD SCT class and my personal experience dates back to the discontinued SCT410.3 platform, but I will share my observations at the local 1/10 turf and 1/8 dirt tracks in my area. Size of track and jumps doesn't really matter, you need to be a squeaky clean driver if you want to race a Slash for club racing.
I have seen countless drivers show up with a Slash at the clubs in my area and very rarely do we see a Slash make it through a full race day without 1 or more broken parts. Yes there are some key upgrades that will help, but unfortunately most upgrades will also fail due to the dated geometry. Typically by the 3rd or 4th race day, the majority of drivers will come to the realization that they need a true race grade platform.
Don't get me wrong, TEKNO will break too, but not nearly as quickly as the Slash. In the long run, you'll save a lot more money and spend far less time making repairs with a TEKNO.
For the record, I have no affiliation with TEKNO, just trying to help you out :)
Thanks, I will consider it. I like the idea of building the truck from scratch.
Yes I have been looking for races or competitions for my traxxas slash ultimate does anyone know any thanks a lot
Listen to Bill. 4 of us weekend racers switched from Slashes to 410s and couldn't be happier.
What surface?
Budget?
Absolutely. Here is the final, comprehensive list for your 10/10 build, sorted logically by the area of the truck to aid in your assembly.
I. Base Vehicle & Chassis Core
  • Base Vehicle: Traxxas Slash Ultimate 4X4 RTR (Green) - 68277-4-GRN
  • Front Bulkhead: RCMYou Aluminum Front Bulkhead (Red)
  • Rear Bulkhead: RCMYou Aluminum Rear Bulkhead (Red)
  • Center Differential: Traxxas 6780 (Complete Kit)
  • Center Protection: Chassis Guard Dust Resist Dirt Cover for Traxxas 4x4 LCG
  • Battery Hold-Down: Aluminum 7075 Alloy Retainer
  • Threadlocker: Loctite 242 (Blue, Removable)
II. Suspension & Drivetrain
  • Driveshafts (Unbreakable): MIP 18145 (X-Duty CVD Drive Kit, Front & Rear)
  • Suspension Arms (Lower): RPM 80702 (x2 Pkgs, Black Front + Rear)
  • Front Bumper: RPM 80952 (Front Bumper/Skid, Black)
  • Rear Bumper: RPM 80122 (Rear Bumper, Black)
  • Tires: Pro-Line PRO1015610 (Badlands MX SC, Qty 4)
III. Steering System
  • Steering Servo (High Torque): HobbyPark 45KG Servo (Coreless, Stainless Steel Gears)
  • Steering Bellcranks: Traxxas 3743A (Anodized Blue Aluminum)
  • Servo Arm: GPM Aluminum Alloy Straight Arm (25T Spline)
IV. Fluids & Tuning
  • Diff Fluid: Team Associated ASC5457 (30,000 CST Silicone Diff Fluid)
  • Shock Oil: Traxxas 5033 (40wt / 500 CST Silicone Shock Oil)
V. Electronics & Power
  • Charger (Smart Dual): gensacearespammers IMARS D300
  • Batteries: Zeee 7200mAh 7.4V (2S LiPo, 2 Pack)
  • Cooling Fan Set: VXL-3s ESC Cooling Fan and Motor Dual Fan Set
  • Connectors: RC LiPo Battery Connector Adapter (Traxxas to EC5)
  • Safety: PAWBOSE 2pcs Lipo Battery Bag (Fireproof LiPo Guard)
VI. Body & Tools
  • Body (Custom): Traxxas 6965R (Heavy Duty Clear Body)
  • Body Mounts: Traxxas 6815R (Body Mount Set, x2 Pkgs)
  • Body Clips: HobbyPark Universal RC Car Body Clips and Retainer (20pcs)
  • Paint (White): Pro-Line PRO643600
  • Paint (Black): Pro-Line PRO643601
  • Tools: Wera 5118156001 (6-Piece Hex Driver Set)
