Basically, the .15 FE uses a standard small block. And most .12-.18 size engines use a block of similar size. So you could use any .12-.18 size engine and it will pretty much drop in. Like kwong and a few others have said, there may not be enough room to use the EZ start, though. If you have a TRX .15 Pro, you can get a pull start for like $15 for it and that will solve that. My $.02? Beat the hell out of your .15FE for now just getting used to driving the car. Then when you burn that one up, move on to something beefier.
