A 2s lipo (be sure to enable lipo low voltage cutoff), or a 8.4v nimh battery. Add the option pinion. Just watch your temps if in grass or rougher terrain. You can look up optional gearing ratios by swapping spur/pinion combos also as well as different size tires which change the final drive ratio.
