slw2206
RCTalk Qualifier
- Spring Mills, PA
- Racing
- Flying
I'm looking for battery options for my Traxxas XRT and in the process I'll be searching for a little education (or confirmation that my thinking is correct).
I currently have Traxxas 4s 6700mah packs and their Id chargers for our XRTs. 2 chargers, 8 packs so we're pretty well invested there.
My understanding is that there are lots of aftermarket LiPO options out there that may offer better performance than the Traxxas packs, so Id like recommendations on what I should be looking at.
My 2nd understanding is that the way Traxxas packs are wired to work with the ID charger means other manufacturers batteries may not work with my ID charger. As I research that point I see that my Traxxas chargers have a little plastic faceplate next to the main charger with 3 pin connectors (balance leads?). Does this mean that I can use other manufacturers packs with my ID charger? I just need to plug in 2 connectors per pack when charging?
Not sure if what I stated above is correct so looking for confirmation.
In summary:
1) What aftermarket LiPOs should I look at for maximum capacity + performance?
2) Is my understanding of the connectors correct? Can I use my ID chargers for other manufacturers packs knowing that I have the pin connectors next to the main terminal?
In summary:
