traxxas 6s esc
Huyyy
Hello! i have a question..
Can my 4268 2150kv Skyrc Toro X8 Pro motor work with the 6s traxxas esc
does it have any problems from that
only issue one might encounter is if a motor is censored and esc is not,not the case here this will work together
my 4268 has sensor port can i use that esc for my motor
Yes. You don't need to use the sensor part of a motor to have it work with a sensorless esc.
I've run motors that have a sensored option on a non-sensored capable ESC.
Here's a quote from Castle Creations
Can I run a sensored motor on a non-sensored ESC (IE Sidewinder 4 or Mamba Monster 2)?
Absolutely! But you will not be able to utilize the sensored capabilities of the motor. The ESC will simply run the motor sensorless; it will perform exactly the same as a non-sensored motor. Just connect the three primary motor wires and set aside the sensor cable that came with the motor. There is no disadvantage to running a sensored motor on a non-sensored ESC
