Thank you for getting back to me. Yes I have the XL5 ESC. I tried moving the wires and checked for a loos connection that made no change.Hi.. do you have the xl5 esc?. if yes check the bullet plugs inside the clear shield on the red and black wire then wiggle the red and black wire might be a loose solder joint either on motor or esc
Thank you for getting back to me . Yes I have determined that it is the motor, I connected it directly to the battery it does not spin.You might wanna try XL-5 HV Setup Programming (Calibrating your ESC and transmitter) in your manual (page 18). Check your motor also, hook the motor leads directly to a battery (since it's a brushed motor) to see if the motor spins or not. If it doesn't replace the motor or at least try cleaning the motor out and try again.
