The stock carb gap is 1mm and that is factory setting. + 1/2 turn is ok. I suspect you have something more wrong if you have to open 2 mm. How are you setting the low needle. It should be flush with the barrel not the ball linkage ( if you set to ball linkage then 1 turn in or .020 in). The high should be 4-1/2 to start but don't go past 4 turns out. You may have blockage or crap stuck inside needles. or the carb body is bad. Once the idle screw hole strips out. I would just buy a new carb. As for using super glue it just doesn't work well.
