Traxxas 2WD Rear Shock Tower screws
DavidB1126
Team Bomb Pop
Bomb Pop Island
On my rusty, the rear shock tower screws to mount it, they keep backing out. The ones that go into the tranny case and chassis. Tried ca glue and super glue and that didn't work. Already have a spare RPM tower. And planning to get a new tranny case and chassis anyways.
try red Loctite.. if you have 1 try a longer screw . you will have to cut it shorter to prevent trans gear interference. You can use a larger diameter screw .you just need to cut screw to self thread
This is one of many fundamental design flaws that I recommend upgrading with shock parts from another brand of 2WD SCT on the market, I used HPI Blitz parts at the time where I used their longer M3x25 screw to go all the way through the shock tower from the back side and then use their shock bushings to go into the TRX shock caps and backed with a flanged M3 nut to secure each shock. If I had to source parts today, I'd try the PR Racing SC201:
Get the Hot Racing aluminum trans case. Or even their plastic one is better than the OEM one.
He's referring to the screws that mount the shock tower to the transmission. Not the shock mounting screws.
I think that's the same one @luke66 runs in his MM rustler.
If I MM convert mine, I'm fine with it. But I will miss having a rear mount for a wheelie bar or bumper. With both the slash and rustler m. I already told him to design something
Design a block that bolts to the mounts where the tranny did to the chassis. Tap and dye the block and use steering turn buckles. 2 on top of said block, 2 on sides. Then on the wheel mount you need a spacer to mount the other turnbuckle ends.
I'll see if I have mine to get a picture of. 15 years ago I'm not sure I still have it.
You don't have to mount it in mid configuration. And you can make the RPM wheelie bar mount work with an extra bushing. See my build thread on the drag Slash for more info 😉
You could try creating a plastic slurry. Take some acetone (mom's nail polish remover) and drop some bits of plastic in it. Once it melts, use a toothpick and smear it inside the holes. Some plastic doesn't melt with acetone though. Find some that does.
