I'm waiting for clarification but so far I've been told that the TopCad stuff is 6061 and the boom racing is 6065 aluminum. I'm waiting for them to clarify if its base 6061 or if its 6061-T4 or T6. T4 and T6 is good, base 6061 is crap. We'll see what they say. The 6065 is good. theres not a lot of info on the net about it. It seems to be an uncommon type of aluminum but the info i did find on it suggest that its on par with 6061-T6. I'll report back once they answer me. If its 6061 they might as well put Integy on it. O_O
To clarify one of my earlier statements I said that 6061-T6 is aircraft grade aluminum but while I was reading up on 6065 earlier I read something that indicated that base 6061 is also considered aircraft grade. For those of you that might want to quantify the difference in strength between 6061 and 6061-T6...Base 6061 has a max tensile strength of 18,000psi and a max yield strength of 8,000psi. In comparison 6061-T6 has maximum tensile strength of 42,000psi and a maximum yield strength of 35,000psi. Waaaaaay stronger
