:trashed:
Yeah, if you have access to a garage, you can break it in there. Here is what you need to do. Go to any department store and pick up a little portable ceramic heater if you don't already have one.
Take the tires off of the truck and strap the truck to some kind of brace or stand.
Now turn the heater on and point it so the heat blows on the engine. Now you can go ahead and break in your truck. The truck is going to be getting the warm air from the heater so it will actually think it's summer time. Make sure the heat is blowing in the direction that the truck would be traveling. For example, the heater should be blowing on the front of the truck so the fresh warm air goes into the filter and blows across the motor.
Keep an eye on the distance your truck is from the heater, because if it's too close you can melt stuff, but if it's too far away then you won't be heating the engine up.
Also make sure that you, or anyone else is in the garage, because the fumes are toxious.
That's it......
