The first thing you need to do before starting any project is think.
- What do I want to accomplish?
- What do I need to do it right?
- What are my road blocks?
- How do I remove my road blocks?
In this case you want to glue tires.
You need Glue, rims, and tires.
Your road blocks are getting the tires to stick.
What would make them not stick?
Un clean surfaces and or the wrong glue.
Now you need to research the glue to get. This is a hobby where gluing tires is common. Get Tire glue.
Clean the surfaces you are going to glue. What are they made out of? Molded Plastic and rubber. What do they use while molding plastic and rubber parts to keep them from sticking to the mold? Oil my friend. What cleans oil and doesn't leave a residue? DA. Go get some DA. What else might keep them from sticking? A sealed surface. (Chrome) Remove the chrome. The rubber is pores and will absorb the glue so you have no worries there. WHat else make two surfaces stick better? A scuffed surface. Now you need some fine sand paper or something similar. WHat does sanding do? It leaves dust. Clean the rims with DA again. Read the directions on the glue to tell you the best way to use it. Read yes I said the dirty words Read the directions.
Now after thinking, reading, and thinking again, go and do the job properly the first time. Your brain is the best tool you have. If you remember to think first you will have a lot better success in life.
-Ed
