I clean the rims with soap & water, then 400grt sand paper the mounting areas, then red lean the mounting areas with denatured alcohol.
I then clean & Gorilla tape the tires, clean the beads, and use either rubber bands or electrical tape around the tire tread to make the bead sit well, then glue them with a fresh tube of CA.
