Throttle Servo
Newsboy
This has just stumped me. I have the stock servo in my Revo. It is not hitting anything but the servo will only open the throttle about 30%. I have tried to change the setting on the controller but it does nothing. Any ideas?
I would go with MHM on that. I remember have to fix that on mine a while back after I replaced the servo
Thanks for the help guys. Took some things apart, made some adjustments, and by Gods grace got it put back together :first_place:. Now I just need to get my brakes to work again :D
when i 1st got my revo it did that but it opened about 75% and i didnt notice for awhile i did like mhm said but i had to move the carb slide a couple times by hand to free it up or something cause it would kinda stick and not want to open
You can also turn the carb a bit to get it to have more movement. The stock TRS is a bit stiff and really works the servo hard. I redo the linkage on mine so I can use a softer TRS, but I also use a better servo that moves very easily when power is cut.
