I just completed my SS kit and I have a couple questions. I did the OFNA linkage mod and as I was testing/setting up my linkages,for some reason at wide open throttle the brakes are engaging, the brakes are engaging normally when I apply brake, at neutral no brake drag. Do I need to make some kind of adjustment? Also how do I know if the slipper clutch is properly adjusted, I followed the directions in manual(tighten nut all the way then 1/2 turn open). There is still alot of resistance in the spur gear when turned counterclockwise, I am not too familiar with this slipper clutch setup, any tips on this also..thanks
